Hi i have the error code 2000-0146 is this bad
SOURCE: dell inspiron 1520 error code 2000-0146
Yes, it is a hard drive issue and there is no fixing it temporarily without losing your data. The best thing to get your data is to get a USB enclosure for the type of drive it is (if it's a sata drive or a pata drive) or get an adapter that's an all in one (for 3.5, 2.5, and SATA). Then you hook your failing drive up to the converter, put it in the usb port of another computer and then it will show up as another drive that you can open and explore.
SOURCE: dell inspiron 1521 error code 2000-0146
Hi eodnd119,
That's not a good error code. That is telling you your hard drive is bad.
You likely have a drive where sectors are going bad - sometimes they may be readable, sometimes not. But it's just a matter of time before the drive fails completely.
Replace the hard drive.
Good Luck,
Mark
SOURCE: code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
SOURCE: Error Code 2000-0146
I know this is not what you will want to hear, but according to the Dell Support site, error code 2000-0146 indicates: DST Log contains previous error(s). This means that the drive is failing and needs to be replaced. ASAP is best. I would suggest that you backup anything on the current drive that want to move to the new drive. If the computer is under warranty, contact Dell Support and they should ship you a new drive. If there is no warranty remaining, you will need to purchase a similar type of drive. Once you have the new drive, install it and then reinstall your software. It should go more quickly is you can use the recovery CDs that were shipped with the computer originally.
Good luck, and please let me know how it turns out for you.
~ Spoem
SOURCE: Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Testimonial: "Thank you for your help. I don't know what you mean about the thumbs up; I just logged into my account for the first time today and rated you..."
