SOURCE: remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
SOURCE: I have a Crimestopper rs-3. I have had 2 instances
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
SOURCE: my crime stopper remoye start will not work the
try programing the remote again by going to www.crimestopper.com and to the support tab choosing manuals and manuals again with the model number from the unit under your dash find the manual for that model for any other question you can contact their tech support at 800.998.6880 ext 210
