Computers & Internet Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset my toshiba laptop - Toshiba Computers & Internet
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Dec 10, 2010
Anonymous
Expert
Level 2:
Answers
218
Questions
0
Helped
46778
Points
712
Resetting Toshiba is not a big deal. Toshiba has provided a hidden partion on the hard drive which contains the same files on a recovery cd / dvd.
To reinstall your laptop to the factory settings, take these steps(But be very carefull):-
1) Hold down the power button for 10 seconds to switch off your machine.
Unsaved data will be lost.
2) Press and hold the 0 key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state..
7) Click Next to Start recovery.
Hope these steps work for you, if problem remains try contacting your dealer.
Forgot my password on my Toshiba laptop
  1. 1Find An Accessible Computer and Download, Install Windows Password Recovery.
  2. 2Insert Your USB Drive to PC and Create a Bootable Password Reset Disk (Take USB for Example)
  3. 3Then Insert This Created USB Reset Disk to Your Locked Computer and Restart Your PC.
  4. 4Select Admin Account and Reset Toshiba Password.
What can I Do If I Forgot My Toshiba Laptop Password - iSeePassword
https://www.iseepassword.com/forgot-my-toshiba-laptop-password.html..or try this link. Forgot my password on my Toshiba laptop Google Search
tip
Toshiba Reset Password for I Forgot Toshiba Laptop Password
"I need Toshiba password reset! How do I reset Toshiba laptop? I would be appreciated if you help me Toshiba password recovery, etc." Well, so frequently to meet these problems in our lives. Today, we together share some ways to reset Toshiba password.
Solution1: Toshiba recovery disks help reset lost password
It only works if we created the recovery disks or CD before we forgot the password. The following listed are the steps to reset disk for Toshiba Windows 7 recovery:
a. Start PC, log on Windows 7 and insert an USB flash drive into the driver.
b. Start -> Control Panel -> User Accounts and Family Safety -> User Accounts -> Create a password reset disk.
c. In welcome screen click "Next" and select the inserted USB flash drive, click "Next".
d. Input the login password in the password field and click "Next". When progress indicator shows 100% complete, click Finish to exit. Remove the USB driver from PC.
The method is similar to create a Toshiba recovery CD. Now, the Toshiba Windows 7 password recovery disk is ok. Put it in a safe place for people may use it to reset your password.
Steps to recover password with created Toshiba password reset disk:
e. Click "Reset Password" in the Windows 7 logon window,
f. Insert the created Toshiba recovery USB disk into the USB driver interface, and click "Reset password" to open Password Reset Wizard. Click "Next" to continue.
g. Choose this USB disk recovery Toshiba from the drop down box. Click "Next" to continue.
h. Input a new password and re-input it again to confirm. Click "Next" and then "Finish" to close the wizard.
Solution2: Reset Toshiba laptop by accounts with administrator rights
If there is default or built-in admin account or other accounts with administrator privileges and rights, we can use it for Toshiba password bypass. Take Toshiba XP recovery as example:
A. Boot system from Safe Mode by pressing F8 when PC stars.
B. Access PC with the available account with administrator rights and privileges.
C. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER - Local Users and Groups - choose Users.
D. Right click the account with unlocked password, select Set Password and then input and confirm the new password.
Solution3: Reset Toshiba password with burned ISO image file
We can burn an .iso image file into a bootable USB disk or CD/DVD and reset the forgotten password easily and quickly. Take one of the most popular Windows password reset tool - Ainorsoft Windows Password Recovery as example:
a. Download the program from an accessible PC;
b. Burn its .iso file to a blank CD/DVD or USB disk;
c. Bypass the lost Toshiba password with the burned CD/DVD on the locked PC.
Things will not be tricky if we know the methods for Toshiba password reset once we forgot Toshiba laptop password! Please also remember to share them with your friends!
source: http://windowspasswordrecovery.net/article/toshiba-password-reset.html
Won't factory reset c55d-5319 toshiba satellite laptop....
From your question, it is understood that you want to factory reset your Toshiba laptop. If this is the case, follow the instructions mentioned on the link below for the same:
https://support.toshiba.com/support/viewContentDetail?contentId=2737864
GuruAid.com
2helpful
Bios password for toshiba laptop needs reset
Try This: Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptopsmag-glass_10x10.gif can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
3helpful
3answers
How to Reset BIOS Password Toshiba Satellite A135
Hi! In order to reset the BIOS password for your toshiba laptop, you need to bring the NB to the nearest Authorized Service Provider for Toshiba since only a certified Toshiba Technician can reset the BIOS Password. The technician will remove the jumper inside the laptop which is integrated on the motherboard and the BIOS Password will be reset. All issues regarding the BIOS Password are directly handled by Toshiba Authorized Service Provider.
Hope this helps!!!
Thanks
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
