Avaya 4610SW IP Phone Logo
Posted on Dec 10, 2010
Incoming calls goes to voicemail, then to receptionist. Also rings at three extensions at the same time.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2823
Points
It sounds like all the incoming calls are going to a hunt group. This would explain why three extensions ring, then it goes to the receptionist, and then ends up in voicemail.
Try looking for a hunt group that distributes to the three extensions in question, or that only has those 3 extensions active.
2answers
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
2answers
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
4helpful
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 • Cell Phones
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
2helpful
Auto attendant does not pick
What kind of phone system? If Partner, it sounds alot like you lost all your programming, so the phone system isnt programmed to know where the voicemail is. So hwen a call comes in, the ports where the voicemail is, ring, so they pick up, but dont know what they are to do with the call, so they shove it to the receptionist.
#505 needs to be programmed, then #206, that will get you to at least asnwer incoming calls.
Need to know more, like WHAT KIND OF SYSTEM.
3helpful
2answers
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Voicemail won't allow recording transfers back to receptionist!
Are the mailboxes set up?? What happens is a call goes to an extension, there is one program set to tell the system that if a call rings 4 times, go here(voicemail). Once it goes there, the voicemail system sees that there is or is not a mailbox matching that extension. If there is, the call goes to voicemail, if not, it transfers to the operator.
OR.....Does your system display the correct time? Its possible that the phone system lost its programming, and doesnt know where the voicemail is.
Both might need a professional tech on site...a bit too hard to help over a forum.
3helpful
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
