I think that the internal wiring got short circuited or any other kind of malfunction can also happen. To know this in a deeper manner, there is no need to dug deep. Simply click here and all of your questions can be solved easily: Top 5 Best Electric Kettle
Maybe you have the same problem as this kettle...
Will not heat water
SOURCE: sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
SOURCE: a black ant got stuck under see through window
Fill Up Your unit full of Water and Emty it . Do it few time and Garanty your Ant will Go for Ride..Then Invite her for Coffee ...Bye
