SOURCE: Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
SOURCE: Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
