SOURCE: D-Link DI-604 Router can be use in Wireless Broadband?
You can use any wireless access point. If you would like to stay with Dlink, you could try the DWL-2100AP. You would just need to plug it in to an open port on your router.
SOURCE: Placing Sppedstream Modem 4200 in bridge mode
Plug your speadstream modem into your router via ethernet cable. Make sure router and modem are powered on. Once you have conected the two and the power is on just push and hold the reset button on the modem for the count of five. Your modem has now been bridged with your router....It worked for me and I have the same modem just different router. I hop this helps you good luck :)
SOURCE: D-Link Di-604 bridge?
I had no problem finding the Di-604 on the D-Link site.
http://support.dlink.com/products/view.asp?productid=DI%2D604
SOURCE: I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
