The latch may already be latched like it is closed. You can take a screw driver and put it.. where the latch engages Slightly pry outward agianst the latch while pulling on the door handle. That should release the latch. If you continue to have the problem than the latch will have to be replaced because there is a plastic piece that may be worn out.You will have to remove the door panel to replace the latch. They sell a book on that car that will explain how to remove the door handle(at O'rielly).
