Intermatic Outdoor Timer/Photo Control HB51RC Logo
Posted on Dec 09, 2010
Will the HB51R have to be placed outside to work on dusk to dawn.
A
Anonymous
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
Can I use LED bulbs in dusk to dawn light fixtures?
You will need an LED Bulb that states 'Dimmable'. They have different circuitry and a little more expensive.
https://www.google.com/search?q=dimmable+led+spotlights
Why is my outside dusc to dawn light buzzing
ballast make the noise, especially when they age. an old ballast that is buzzing will not last long.
Jun 21, 2014 • Home
2helpful
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
7helpful
Lost instructions for photocell Type:ET321
Here is how it works. The push button repeats itself in following sequence (must plug in).
F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off.
1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings.
A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (on from dust, but off randomly) time shows no pattern to outsiders.
d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion.
1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
6helpful
I am looking for a download link for the First Alert ET321 with photocell. I have misplaced the original package instructions and cannot find this material anywhere! Your assistance would be greatly...
Here is how it works. The push button repeats itself in following sequence (must plug in). F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off. 1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings. A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (I believe the on time is within the range of 1 hour from dusk set by the timer) and off (it is randomly set, you can see the display blinking showing the selected countdown hours) shows no pattern to outsiders. d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion. 1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
9helpful
Instruction for first alert et321 timer
F: timer is off.
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Setting
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk + override lets timer run during daylight hours
F > Lights are OFF
O > Constant ON
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
