Dell Dimension 4600 PC Desktop Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times, but never boots up. When I put the original cards back in it works fine (still slow) I am installing a 1 gb, ddr, pc3200 card.
Anonymous
Level 2:
Genius:
  • Dell Expert 1,325 Answers
  • Posted on Dec 09, 2010
Anonymous
Dell Expert
Level 2:
Genius:
Answers
1325
Questions
Helped
344210
Points
292
Hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
1helpful
3answers
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
2helpful
Just need to know how to change the ram in my Sony Vaio PCG-v505ap
visit vaio manual in
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/
You can do this in two ways: opening your notebook and taking a look on the memory modules already installed (we will explain more about this later) or running a program like Everest (available on our download section). We ran Everest (going to Motherboard, Chipset, Memory Slots) on our notebook and found that it was using two 256 MB DDR-SDRAM PC2700 (“DDR333”) modules, for a total of 512 MB.
imageview.php?image=1680
click to enlarge
Figure 1: Checking your current memory configuration with Everest.
If your notebook has an empty memory slot, just go to the computer store and buy a new SO-DIMM module with the same technology (SDRAM or DDR-SDRAM) and speed of any capacity you want – of course you need to know the capacity limit of your notebook. You cannot install a 1 GB module in a notebook that only accepts modules up to 512 MB, for example. Our notebook – a Sony Vaio PCG-V505ECP – accepts modules up to 1 GB, for a total of 2 GB RAM, since it has two memory slots.
For example, if your notebook has one 256 MB module and an empty memory slot, if you buy and install another 256 MB module, it will have 512 MB RAM. If you buy and install a 512 MB module, your notebook will have 768 MB.
If your notebook already has two memory modules, you will need to remove one of the installed modules in order to install the new one. If the two modules have the same capacity, it doesn’t matter which one you will take away, but if they have different capacities, remove the one with smaller capacity. The new RAM capacity of your notebook will be of the capacity of the remaining module plus the capacity of the new module.
In our case, our notebook has two 256 MB modules. So we will remove one of these modules and install a new one on its place. We bought a 1 GB-module, so after installing it our notebook will have 1,280 MB RAM installed (memory math is tricky, since 1 GB equals to 1,024 MB not 1,000; so 1,024 MB + 256 MB = 1,280 MB).
else visit
http://www.hardwaresecrets.com/article/189/1
1helpful
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
(non-ECC)
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
