SOURCE: fetal error on HP laser jet 1160
Hi naseeh83: Here your problem. Fuser error. The fuser has a malfunction. Try these steps. 1. Unplug the printer for at least ten minutes. 2. Verify that the fuser connector and thermistor connector are both firmly seated in the ECU 3. Perform a heating element resistance check. 4. If the resistance readings are correct, but the error persists, replace the fuser. You may have to call a certified HP technician to repair this printer. Hope this helps.
SOURCE: i have fetal error code 08H,14H &15H in
When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
