From your phone, press PROGRAM, press a button to be programmed and dial ! plus the extension and ENTER. Pick up the handset and drop it back down to exit programming.
Carl
Testimonial: "you're a star... thank you... been buggin the hell out of me :)"
From the phone press the Pause button then select the down arrow navigation button and it should display "Ext - " then enter the extension you want programmed and press enter. You can press the next CO button for programming or the Pause button to exit. I believe you was on the right track, I found out that if the Ext - is not before the extension that you want, it will not use the red light when the extension is in use.
Jeremy
