Need to install driver? my Gmini xs100 is now empty--no music/drivers/system info/etc. i caused this problem by, first, adding music from itunes--which wouldn't play on this unit. then, erased the new music. perhaps i deleted something that i shouldn't have, because the unit would not play the music that was there before the new itunes stuff. using windows vista os, the prompt asked if i wanted to format, and i clicked 'yes.' so, now the unit is empty, and i cannot add anything to it. can you help? please advise how to fix this problem. thank you~~!!
IF YOU HAVE NO INSTALL DRIVER
GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, UPDATE DRIVER SELECT DRIVER PATH
AD INSTALL IT
IF YOU HAVE NO DRIVER, GO TO MY COMPUTER, MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE ON DRIVER DETAILS
OPEN http://devid.info SITE AND DOWNLOAD SUITABLE DRIVER AND INSTALL TO USE ABOVE STEPS
ENJOY IT
copy: Toshiba Satellite L40 PSL4CE device drivers into google and try to access the toshiba sites driver directory, if you can just download the driver for your original hardware and install it, when you have done this you may be able to bypass the bugs you created when re-installing windows or the video card, if this is so then you wont need to registry edit anything, if it doesn't work then download a registry editing/fixing utility such as vista manager, run it then try to reinstall your respective driver/s again, hope this works for you....;-)
Go into DEVICE MANAGER and see what info you get there about the card. It should give more info on DRIVERS, IRQ, etc. Maybe it is having a conflict with another device. Also maybe re-install the software or go to Mfgs. website to check for patches or up-dates.
I had similar problem at Archos Gemini 202s. ARClib would crash. I solved as follows: Created a folder on the 202. Moved half my files and folders from the Music folder (via de PC, of course). Then checked for correct update of ARClib. If not, I swapped the contents of the folders and checked with the other half. If update is succesful, it is now known what half is the faulty one.
Now, try to troubleshoot this faulty half in the same way. And so on. Quite quickly, you know what file(s) cause the problem. Good luck!
