Turn the printer off (using the power switch at the back of the printer), wait 15 seconds and turn the printer on. If the error continues, replace the Line Sensor.
(Check the error code closely to see the first two digits...this series does NOT have any 00 codes, it could be 0D)
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it.
Here is what I did to resolve sync errors:
1. Perform a hard reset on the Palm
2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old.
3. Connect the Treo to your computer.
4. Right click the Hotsync icon in the taskbar and click Custom.
Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld.
5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
I was ready to give up completely. Uninstalled, reinstalled, nothing worked.
5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now.
This worked for me. I hope it helps with your errors.
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
I did search through the forums before posting and the only "solution" I found was to buy Chapura PocketMirror for $30 which I refuse to do. I should be able to sync this palm with Office without having to spend even more money.
Updated Instructions
Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650).
1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu.
2). Turn off phone.
3). Set the Date/Time to the maximum limits (12/31/31) in Preferences.
4). Open the Calendar and view the maximum day 12/31/31.
5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu.
6). Reset the Date/Time to the current day in Preferences.
7). Hotsync (Desktop Calendar overwrites handheld).
8). Hotsync again to make sure you don’t get the error (Synchronize the files).
That’s it.
Outlook Calendar
The attempt to open the database failed.
Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize.
OLERR:05-0001
OLERR:0D-0004
OLERR:0D-0001
- Not Synchronized
Outlook Calendar synchronization failed
OLERR:15-0002
OLERR:06-0001
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
