SOURCE: Just got a Sandisk Sansa
Go into device manager under Start --> Control Panel --> system --> Hardware --> Device Manager --> right click device and follow any troubleshooting that Microsoft reccomends
If that fails to resolve, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
SOURCE: lOST INSTALLATION DISK FOR SANDISK SANSA FUZE
go to this website , they will have what you need to download, www.sandisk.com
SOURCE: sandisk sansa fuze mp3 4GB* (red) won't work right
we just got a sansa fuze and downloaded media player but its put everything photos and music from my husbands computer on to it, its for my son how do we remove it all? HELP!
SOURCE: Sandisk Sansa
your in the wrong item. This is the sansa e250 which has different software. Besides the normal plug in and view hidden folders - then drag and drop, i cant really offer advice as im unfamilar with the fuze but if you repost your question under the fuze hopefully someone else can help you.
SOURCE: sandisk sansa fuze not connect to the pc
Could be a couple of things. There may be damage to the USB port on either the player or your PC. The cable may also be defective. If you are using an older PC, it may not use the right USB technology for the device. Newer devices use USB 2.0 which looks the same as the original USB technology, but is much faster.
