Question about Lakewood Oil-Filled Electric Radiator Heater
I have an old Lakewood 7000/A Heater which has not been used in a very long time. When I plugged it in I can hear a popping noise that I think is the oil heating. Is there a danger in using the heater while it's making the popping noise. I don't remember it ever making the noise before when we used it.
    New Friend:
This is a normal noise while the unit is initially warming up...it shouldn't be making this noise once it warms up though
Posted on Dec 09, 2010
6ya staff
SOURCE:
Replacement wheel for Lakewood Heater Model 7101
I did the drill think once. but today when trying to repair an old Lakewood 7101, I removed the two screws holding the front cover in place (top and bottom). the cover slides down and out. and underneath I see a large plug that can be unscrewed to drain or fill the heater!
Sep 02, 2012 | Lakewood Heating & Cooling
Lakewood space heater thermostat source
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Dec 31, 2009 | Lakewood 5101 Oil Filled Radiator Heater
Need new electric cord for model 7000/a lakewood heater oil filled
Depending on handy you are, the power cords for heaters can be replaced, but may require soldering or other electrical and mechanical skills. You MUST replace the cord with one that has the same amperage and heat ratings.....that goes for the plug too.
Feb 20, 2009 | Lakewood 7101 Oil Filled Radiator Heater
No more parts for Lakewood 7000
Did you try the other service center info on this page http://www.lakewoodeng.com/html/parts.html nelsons is listed as well as the other place. It may be that your unit is just old enough no one is going to have parts anymore. The should be able to tell you that one way or the other.
Dec 04, 2008 | Lakewood Oil-Filled Electric Radiator...
ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Aug 27, 2008 | Lakewood Heating & Cooling
Lakewood Oil-Filled Electric Radiator Heater Logo
2,066 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
