How can I remove the stand of the Insignia ns-ltdvd26-09? I am wall mounting the tv.
I struggled with this at first but realized it was simple in the end!!
1 - Locate and remove 4 screws at the bottom rear cover of TV (they connect the rear cover to the metal shaft of the stand) these screws are recessed deep into the the rear unlike the screws that are around the edges.
2 - Then remove the 2 screws that are located just above the base of the TV stand and at the bottom of the rear cover of TV.
3 - Pull base from bottom and it will slide out very easily.
4 - Dont forget to replace the 6 screws back into the rear cover of TV.
We just got an Insignia and had the same problem. We finally figured out there was a "hidden" screw inside the bottom bracket hole (for each side) of the stand and one screw (for each side of the bracket) at the bottom of the back of the TV right above the stand. Once we removed these four screws (two for each side) then the TV lifted right off. Hope this helps.
I cant mount up the tv to the base, help
Q - How can I remove my LCD from its factory-installed stand?
A - To remove the base of the LCD TV you need to use a Phillips screw driver and remove all screws attached to the metal bracket that holds the LCD TV base in place.
TRY THIS www.insignia-products.com
SOURCE: Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
I also can't get the base off and can't figure out for the life of me why it doesn't say it in the manual. This is my 4th LCD Tv and I can't believe this is so difficult.
I have the TV stand off but there is a large silver bolt sticking out and I can not remove it.
I am having the same problem. I've removed all the screws and the big bolt in the center of the steel support is so tight I can't get a wrench around it to remove it. This is insanely difficult for such a simple question.
I want to mount this tv to the freakin wall but the four small screws on the back of the tv don't really look big enough are they? i have tilting wall mount sanus model mt25-b1 from best buy they said it would work does anyone know whats up.
I am converting mine back from a wall mount to a stand mount. However I lost the base. Can I get one from one of you wall mount guys? thanks [email protected]
remove base of Insignia ns-ltdvd26-09. How do I do this?
