Canon PIXMA MP210 Photo All-In-One Printer Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My canon mp 610 keeps showing an error message no paper no matter how much or how little is loaded in the rear try any ideas I have cleaned rollers heads everything grrrr
Lance Hill
Level 3:
Genius:
  • Master 1,739 Answers
  • Posted on Dec 09, 2010
Lance Hill
Master
Level 3:
Genius:
Answers
1739
Questions
Helped
799945
Points
4235
Is this an MP610 or an MP210? was there any error codes in the display?
If it is the MP610:
Issue: ERROR LCD: There is no paper. Load paper and press [OK].
Solution: Press ON/OFF switch to reset the multifunction device.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
You may also find this helpful; don't forget to press the paper feed switch after loading until the cassette lamp lights: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp610#ServiceAndSupport
2answers
Message comes up 'there is no paper load paper and press OK?
if your device has multiple trays, please put paper in both trays before attempting to print again. I would also use any diagnosis apps that Canon offers on it's website for it's product after power cycling your device and restarting any computer that it might be attached to.
Thank you.
I get a "no paper" message from my Canon MP-560 when there is paper in the rear tray. What can I do to fix it?
make sure paper is loaded in right port and paper is inserted all the way. try a few pages at a time, and refer to manual on proper paper path information.
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
3helpful
2answers
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
2answers
The paper starts to feed on the canon pixma mp 160 but when i try to print or copy, paper doesn't continue to feed and I get an E message. any suggestions
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-7
1helpful
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
1helpful
I have canon PIXMA MP
E3 error on the MP150 is a paper jam error. Make sure that there is nothing obstructing the paper going into the printer and that the feed mechanism doesn't have anyhting in it. Also run a roller cleaning from the printer software.
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
2answers
Will not function on front feed
check all paper paths for little pieces of paper
7helpful
3answers
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
old marine
old marine
ZJ Limited
ZJ Limited
