Where do i find a battery for this camera? it is a Minolta Maxxum 300si 35mm camera.
I got a 2CR5 battery from RadioShack and it does not seem to work in this camera. any suggestions or information?
thank you!
It takes either: Energizer 475 or Duracell 245........if camera still will not fire, your camera has a problem. www.flcamerarepair.com
Minolta Maxxum 600 Si with vertical grip using 4 AA batteries returns HELP error message in LCD screen and locks the camera after a few shots with new fresh batteries. To reset back the camera I have to extract the battery pack. I Cannot replicate error with 2CR5 battery as it is no longer available. It occurs on both 28 mm and 50 mm lens.
Minolta Maxxum 600 Si with vertical grip loaded with 4 AA alkaline batteries returns after a few shots HELP message on the LCD and renders inoperable the camera. I have to extract the battery pack from the vertical grip and insert it back again to reset and two or three shots again it blocks the camera. There are no 2CR5 batteries available to test with these batteries. Problem occurs with both Maxxum 28 mm and 50 mm lenses.
