Question about Sanyo STW0923H2 Air Conditioner Heat Pump
Have three levels about 800 square feet each. will I save energy costs by keeping level 1 and 2 at 55 degrees with doors closed and using ptac on third level at low heat and low temperature settings with ceiling fan, and turning off when not in room? Or is it better to reside on level 2 at a warmer temperature? Outside temp average will be 25 degrees for 2 months. PTAC use has been comfortable with seemingly little strain x 1 week. PTAC unit new. Thanx
    Genius:
  • 1,547 Answers
Heat rises yes you will save energy this way
Posted on Dec 08, 2010
6ya staff
SOURCE:
Just installed a new kitchen aide dishweasher and the door doesnt quite lay flat at 90 degrees making it difficult to load the rack
Is the DW level with the floor? What does a bubble level on laying flat across the bottom a rack say? Sloping toward the back? If so adjust leveling feet under the front. The other possibility is that you need to adjust one or both springs back a notch (Use a forked weed tool to take and replace the springs in notches to save your hands. This indicated by the door extending level if you push gently while open. I vote first option. Leveling Dishwasher
Mar 08, 2018 | Dishwashers
Tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 | Heating & Cooling
Fisher and paykel fridge is making a whining noise only when door is closed. Thanks in advance.
If this is a large cabinet or larder fridge the cabinet is not rigid enough to maintain it's shape unless it rigidly stands level and square. It can take a deal of time and effort to adjust the front feet in order to level and square the cabinet on a relatively flat floor and sometimes it is impossible without first preparing the floor.
It is important for them to stand level and square and at the same time stand firmly on all the feet. If they are allowed to operate out of plumb for any length of time the motor/compressor unit can soon become noisy. Often this is only noticed when the door is closed or open. The door is a major part of the rigidity of the modern fridge and if the fridge is not properly levelled the shape of the cabinet will change as the door is opened and closed causing any compressor noise to be transmitted differently.
The gas charge of the modern fridge can also make weird noises as it is being pumped around the circuit. Ours sometimes sounds like the wind blowing across an open chimney and sometimes like the sea breaking on to a pebble beach and sometimes like something sprung a leak. All this is fairly normal after the fridge has lost it's youthfulness.
Jul 23, 2016 | Fisher and Paykel Refrigerators
The door on the freezer will not keep closed. What could be the problem?
There must be something your not seeing, get an extra set of eyes on it.
Oct 25, 2015 | Frigidaire LFFH17F7HW 16.6 Cubic Feet...
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
Oven door hinges do not keep door closed
Have you tried re-leveling the machine using the adjustable feet?
Jan 16, 2014 | Frigidaire Refrigerators
Bottom drawer does not have a hard stop. Drawer will roll right off the door and on to the floor
check the level of the Dw per the instructions.. may need to raise the front up... If you take the front kick plate off( 2 screws) there are 2 white feet at the front... also phillips screws above(inset) that control the height of the back 2 feet.
Manual tells you where to place the level.. for plumb levelling the manuals stated to put the level on the front side of the cabinet( where the door closes on to)... on the vertical side. Adjust the front feet down, or the back ones upward( need to watch to keep the side to side level when doing this too...
Good luck
Oct 04, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
How to bore a perfect level 1/2 inch hole in wooden door
Some drills have a spirit level built in that help keep things reasonably square and level. I don't particularly trust them, but if you try using it while drilling on a piece of scrap and are happy with the results, it's no extra cost.
If you don't trust yourself to "eyeball it", you can buy a drill guide (see link). If you look at the link, you'll see that it has a flat reference surface you can put up against your door. The chuck on the guide slides up and down the guide posts, so if you set the angle on the posts to 90 degrees you can drill a nice perpendicular hole. I linked to Amazon, but I've seen them in local hardware stores.
Make sure you mark your center point so you can center the bit up properly.
A forstner style bit will cut nice smooth edges. It's pretty easy to stay square using one of them too, because the walls are square to the cutting face.
Whatever you decide, it's probably worth drilling a practice hole on some scrap. It's painful to goof up a door.
If this answer was helpful, please give it a vote. Thanks!
Jun 15, 2010 | Black & Decker Pivot Plus Cordless...
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
Sanyo STW0923H2 Air Conditioner Heat Pump Logo
167 people viewed this question
Top Sanyo Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Dennis Boxerman
jdthefixer
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
