Brother DCP-7030 Digital All-in-One Laser Printer Logo
Posted on Dec 08, 2010
I have dcp-7030 brother printer. its saying toner life and replace the toner cartridge. i have refilled it and also reset to home position but still the same message is coming
  • Anonymous Mar 17, 2013
    i havedcp 7030 brother printer .its saying cartidge error black tonner cartidge
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1819
Points
5
I know how to solve drum end problem along with change tonner.... Send me mail on [email protected]... Thanks
1helpful
2answers
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Toner life end replace cartiage solution
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
1helpful
DCP 7030 printer says toner life end, replace toner cartridge. After replacing the toner printer still gives the same message and will not print.
What worked for me was to follow the instructions in this video: Resetting lever on cartridge There is a lever on the left hand side of the toner cartridge (left hand side - with you holding the cartridge as if you were going to insert it into the printer). It seems that lever has to be at the '12 o'clock' position to tell the printer that you have a new cartridge. The video showed the person removing 3 screws and then ensuring the lever was at the '12 o'clock' position. On my cartridge I had to do some wiggling to get the lever to move as it's gear assembly seemed to want it to only move down to the '4 o'clock position' and then stay there. Eventually I got it moved to 12 o'clock - and when I stuck the toner back into the printer - the 'toner end of life' message went away. I then removed the toner cartridge - as I wanted to try another cartridge that I had also reset the lever on. I found that lever had again moved to the 3 or 4 o'clock position - after printing just one test page so I am guessing it being at the 12 o'clock position tells the printer you have a new cartridge - and then it moves over to the regular position at 3 or 4 o'clock..
8helpful
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
24helpful
2answers
I have a printer dcp 7030 brother company i am showing problem toner life end after reffling
I just had this problem and fixed it. The original toner cartridge that comes with the printer cannot be reset. You have to buy at least one new cartridge. The reason is that the original cartridge that comes with the printer doesn't have a reset flag. You can, however, refill/reset a cartridge that you buy separately. Pull out the drum and lift the cartridge out of the drum. Hold the handle and look on the left end. You should see a crescent shaped hole with a white flag/lever. To reset this, move the white flag all the way to the left (I had to use something to push it). Put it back into the printer and voila - it fixes itself. Then, after the printer has been reset, you can use the original cartridge again, if you want. The flag part won't matter once the printer has been reset. I hope this is clear. I know it worked for me, and I had the exact same problem.
2helpful
Toner Problem.
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
75helpful
5answers
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Norman Weimar
Norman Weimar
k24674
