Computers & Internet Logo
Posted on Dec 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The laptop is a dv6700 HP Pavillion. What steps should I take to solve this issue.
joecoolvette
Level 3:
  • HP Master 5,660 Answers
  • Posted on Dec 08, 2010
joecoolvette
HP Master
Level 3:
Answers
5660
Questions
0
Helped
2192866
Points
18014
About it being an HP Pavilion dv6700 laptop?
Ehhh, giveittome. I will use it.
Looks like I'm going to have to guess since the 'Issue' wasn't stated.
The main problem with the Pavilion dv6700, which is part of the Pavilion dv6000 series of Notebook PC's, is that all the indicator lights come up, but there are no graphics being shown on the LCD screen.
The screen is black.
This is due to a graphics chipset problem, caused by a poor cooling design of HP designers.
The graphics chipset (GPU. Graphics Processing Unit), is mounted to the motherboard in a BGA surface mount.
Instead of pins coming off of the bottom of the chipset, as on the older Processors, there are Solder Balls.
The motherboard has tiny copper pads that line up to the solder balls.
The graphics chipset is set into place, then heat is used to melt the solder balls, and attach the graphics chipset to the motherboard.
Due to the poor cooling design, the graphics chipset overheats, and the solder connections are partially melted.
The graphics chip now has a poor contact to the motherboard.
This video shows you what's going on, and how to solve the problem,
http://www.youtube.com/watch?v=bnkQNmKauEc
This is the download page from HP Support, for the Service Manual (free) for the HP Pavilion dv6700 model series of Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3650965&
On this page click on the file name in blue>
HP Pavilion dv6500, dv6600, and dv6700 Entertainment PCs - Maintenance and Service Guide
This is a PDF file. Allow up to 30 seconds to see the first page, and additional time may be needed to full download.
Regards,
joecoolvette
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
I am getting the message DVD region code error. Change Region to 2 or 5 as its set in 1, and it doesnt allow me to change, I am using HP pavillion dv6700 and Vista home premium. Previously I solved this...
better try with some other player, mostly some patch may not work better . and it is very difficult to find a good patch for your player.. , try other dvd's also
When connected to the web, the screen bounces up and down like I'm scrolling, rapidly, up and down, but I'm not. How do I stop this? I have an HP Pavillion dv6700 notebook PC.
I would suggest you to run the antivirus software you have. Before running , please ensure its updated. That might solve the problem
Thanks
Ranjit
1helpful
Hp dv6700 pavillion mother board bad if it has overheating issue?
it sounds more like the system is overheating to me, they are classic signs.
Have you tried to clean the system fan and the air vents with compressed air? if not try that and see if it stays on longer.
Post back please.
Good luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
