You may be aware that Olevia is bankrupt and apparently Emerson bought the leftovers and is offering service but no parts sales.
I found this thread discussing antoher model's various problems but I believe your power supply has likely failed.
Olevia thread
If it is the type of failure related to the switched-mode power supply, these can be repaired by a properly equipped tech; I've done hundreds of them while still in business (which I am no longer).
Sometimes FixYa's software does strange things- copy and paste the link below that should have been in the message I posted:
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
