Try the procedures in this tip.
SOURCE: Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
Try this and everything should work fine.
If all this hasn't worked then try seting the mode dial on the camera to M manual mode.
Cheers
SOURCE: My pentax option A10 turned black on the screen and won't open
Since the screen went black BEFORE the lens retracted, it makes me think this is a main board problem. The only other possibility is that it is the lens assembly, but since it went black BEFORE the lens retracted, I don't think that is it. I can replace the main board for $40, or you can send it to pentax in Arizona, and they will do it for about $90.
The main board is NOT something that I would suggest anyone try to replace as a DIY project. There are too many small screws, and delicate connections to deal with.
You can contact me at: mrfixitmark at comast dot net
If you just want to sell the camera as-is, I also buy all pentax a10, a20, a30, a40 cameras, in any condition.
SOURCE: pentax camera espio 738g zoom
The camera has a faulty capacitor inside the circuit board. Having it repaired generally cost more than purchasing a replacement camera. Capacitors store the power needed to operate motor drives when needed. If they get a hairline crack on the outer shell they will lose there ability to operate correctly such as yours is doing
SOURCE: I have a trouble with my digital camera. When I
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter).
Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
