I have the exact same problem. I can hear the solenoid "click" but when I try and "blow" threw it I cannot. I removed the little screen filter inside where the copper pipe connects, still no luck. Not sure what the flat blade screw is for with the locking nut, other than to adjust the position of the solenoid. I checked for flow of water outside of the valve. Also my contractor hooked this up to the Hot water side of the water heater. Does anyone know if this is correct? I would think you get more corrosion on this side.
