Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Washing Machine clothes come out stiff, like no fabric softener was put in. I saw the dispenser was empty. It seems like there is an extra rinse cycle on the heavy duty load cycle, and the softener was dispensed early. (the extra rinse option is OFF) Any suggestions?
6ya staff
SOURCE:
Anonymous
  • 209 Answers
SOURCE: water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
Posted on Sep 17, 2007
Anonymous
  • 1028 Answers
SOURCE: i have the duet ht
pull drawer completely out by pressing release tab on left rear of drawer remove all the cups and clean thoroughly with damp rag wipe upper portion on opening before reinstalling drawer
Posted on Aug 07, 2008
Anonymous
SOURCE: fabric softener dispensing before wash begins
I am having the same problem with the soap and fabric softner dispensing into the washer together... before I even shut the door. Shouldn't the softner dipense in the rinse cycle?
Posted on Nov 13, 2008
robocop
Bill Batross
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
Anonymous
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
Whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
Mar 24, 2012 | Whirlpool GHW9150 Duet Washer
My Whirlpool duet sport machine occasionally has "stained" laundry. I can't figure out what causes it since I don't wash colors and whites together. The stains appear to be blue. Could this be a fabric...
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
Sep 16, 2010 | Washing Machines
The soap dispenser works but the bleach and softener dispensers do not
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener won't dispense
Have you tried thinning the softener with water? It's what I used to do on my older washer, it wasn't the new Duet, but it seemed to help. Hope that helps. (PS I don't use softener anymore as I have developed a terrible skin allergy to these newer longer scented softeners! )
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Feb 06, 2009 | Whirlpool Washing Machines
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse cycle
di you try to remove the drawer completely and check for a blockage under he dispenser itself.(sometimes te fabric softener can get kinda gunky.. if you extend the dispenser you see a little black tab in top left corner, push it down and dispenser will release, just in case you didnt know that
Mar 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
this may be due to a faulty solenoid, if the cold water is flowing into the machine under normal use at the start, then check the solenoids as the conditioner has its own, the solenoids are just behind the body where the water pipes fit to the machine, they have 2 wires on each one, and are tested for circuit when machine is unplugged. stat there, hope i have helped
Sep 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
