SOURCE: Epson Stylus Color 660 won't print in black
hi i want driver epson 660 in windows xp pls help me
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
SOURCE: How to remove print head of epson stylus photo r1800 BEWARE SPAM NUMBER +1-800-532-4187 BELOW
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
