SOURCE: hack region code for SV2000
I found this info.....it doesn't work for my model SV2000 ( WV806 ) , but it might for yours SV2000 ( WV10D6 )
With the recorder on stop, not on a menu screen. press on remote; CMSKIP-1-2-3. this will take you to a page labeled "F/W VERSION DISP" this will display the current firmware version and model numbers. To exit , press the "RETURN" button. DO NOT PRESS "OK" on remote , pressing "OK" will reset your player settings.
View disk manufacturer information:
with a disk inserted into recorder and stoped, not on a menu screen; press on remote CMSKIP-1-2-3 to go to firmware information screen.press the rigth arrow "->" once. this will display the disk media type and disk manufacturer ID. To exit, press the left arrow "<-" once to go to the firmware display screen, then press the "RETURN" button. DO NOT PRESS "OK" on remote , pressing "OK" will reset your player settings.
SOURCE: hack
With no disk loaded:
Press the Menu button on your remote control
Press the 5 button on your remote control
Press the 7 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
The currently selected region will be indicated on the onscreen display
Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on,
or the 9 button for multi-region playback
tried this a couple of times but got no joy, but then on my third attempt I pressed the open/close button on the remote by accident instead of pressing Menu twice & hey presto my sr150m is now multiregion!!
Give it a go
SOURCE: Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
SOURCE: Region Hack for standard DVDs LG BD370
Download lg6000.zip .It will solve it! I have posted the net address on a simillar post.Look it up or just ggogle the zip file.
