SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
SOURCE: miele coffee system CVA 2660 is showing fault #10
F10 is a water intake fault. The are several possibilities: the pump may be defective, a piece of lime scale may have blocked a pipe, the water tank might be faulty. Most likely is the pump.
SOURCE: My Miele coffee machine cva
Hi carlo1787,
The PC Board may be reporting a false positive reading.
The descale message is shown if it passes mark set for a certain amount of water used by the machine by the water hardness level.
Simply turn the machine on, and while it is displaying the message, plug it out of the wall (while active) - Leave it off for about 10 minutes, and plug it in again. This should reset any memory on the board.
Kind Regards
JEDEMEYER1
* If this solution helped you, kindly accept it
Have you ever descaled the machine before? Did any water come out of the machine?
