First of all, referencing a 'previous mail' is of little use - at Fixya, posts are made on forums when requesting assistance.
Secondly, you say 'even re-chargeable batteries' - not all re-chargeable batteries are alike. Many people recommend the use of 2500mAh re-chargeable batteries to provide power to cameras.
Thirdly, I cannot comment on the suggestion there may be a fault with this particular model - a Google search may provide more information on this matter.
SOURCE: sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty of sellers out there.
SOURCE: Camera makes noise when switched on and shutter won't release.
I had the same problem. I dropped my 5D about a foot off the ground. Then when I turn it on it would click for a couple of seconds then stop. After playing around with it for a while I think I have it fixed. When the camera turns on it checks all of the setting and the lens. In my case the lens contacts with the camera where disturbed, By wiggling the lens around I was able to get it to work. Let's hope it stays fixed. Give it a try.
SOURCE: BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
SOURCE: Konica Minolta E500: The LCD screen has gone blank
are ur pics black if u see them on pc then
this is a BAD CCD
problem thousands are facing dont worry konica will do it free of
charge even if u are out of warranty and not on list, just call or
contact KONICA see this PLS RATE ME FIXYAfor help
http://www.konicaminoltasupport.com/English.importantnotice_en.0.html
