Sounds like you have to reset the router and put in your info again as when it was new ...
Finally your belkin router will setup and you will able to use the internet. you may try to connect the devices, whatever you want to connect with it.
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
