Ipod touch is disabled says try again in 4438908 minutes I don't have the original computer that it was synced with, I can't restore with I-tunes without the passcode.Ipod touch is disabled says try again in 4438908 minutes I don't have the original computer that it was synced with, I can't restore with I-tunes without the passcode.
AnonymousAug 04, 2008
my iPod touch is disabled and below it says connected to i tunes
AnonymousAug 11, 2008
My iTouch is disabled and tells me to try again in 4283140 minutes. I went to an Apple specialist who said he had never seen this before.My iTouch is disabled and tells me to try again in 4283140 minutes. I went to an Apple specialist who said he had never seen this before.
same as discriber here.............. help!!!!!!!!!!!!!!!!!!!!!!!same as discriber here.............. help!!!!!!!!!!!!!!!!!!!!!!!
AnonymousAug 16, 2008
Have the same problem...its frustrating...what can we do to fix it
AnonymousAug 22, 2008
i charged my ipod the other day cuz it was dead
then i go to turn it on and it says ipod disabled try again in 45373803 minutes
i need help on how do make it work again but i dont wanna plug it into the computer cuz im not home now and i dont have the wire
so plz pl zhelp.i charged my ipod the other day cuz it was dead
so plz pl zhelp.
when i turn on my ipod touch it says ipod is disabled connect to itunes and when i connect it to itunes it says that i cant do anything because it's locked but it wont let me enter the password. what do i do?when i turn on my ipod touch it says ipod is disabled connect to itunes and when i connect it to itunes it says that i cant do anything because it's locked but it wont let me enter the password. what do i do?
AnonymousMay 03, 2009
me2
me2
AnonymousMar 14, 2014
Screen says try again in 22,582,170 minutesScreen says try again in 22,582,170 minutes
Screen says try again in 22,582,166 minutesScreen says try again in 22,582,166 minutes
AnonymousMar 27, 2014
its disabled makin me madits disabled makin me mad
AnonymousMar 29, 2014
i cant get on my ipod touch it is locked upi cant get on my ipod touch it is locked up
You can't post conmments that contain an email address.
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
my daughter has this same problem but has over a thousand photos, her singing videos and important stuff that cannot be replaced, will the above solution erase all the data if she does that? If so,is there any way at all that it can be fixed without deleting everything on her ipod?
She is so upset, please help!!my daughter has this same problem but has over a thousand photos, her singing videos and important stuff that cannot be replaced, will the above solution erase all the data if she does that? If so,is there any way at all that it can be fixed without deleting everything on her ipod?
connect your ipod to itunes and then click on your ipod. then click on updater and your ipod should be good as new.
this process is all on the computer.
try using a program called disk aid it will allow you to take all your music and media off your iPod and then you can restore your Ipod and reinput all your media only used disk aid if you don't have a backup of your media on your iPod touch
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
if you need any further help let me know. Good Luck
press and hold the home and power buttons, when it turns off DO NOT let go of the home button continue holding until it restores itself then connect it to your computer and restore it. unfortunately it will erase everything.
so plz pl zhelp.
i ipdo touch is reading disable try again in 4642200 minutes
me2
