Canon Rebel XT / EOS 350D Digital Camera Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Inspiron computer with WIndows XP suddenly does not recognize camera. Bought new cable. Checked drivers. No change. No viruses. What else should I do?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 12, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469863
Points
19564
Bought new hard drive for mini 1012 dell bios sees new hard drive but when i try to install windows xp , xp says no mass storage device detected.
In the bios change the drive options to anything but AHCI if possible. You will need a windows xp driver and USB floppy disk to install the AHCI or SSD driver. It's also referred to as an F6 Floppy. Dell should have the download you need.
I have a Dell 2300MP projector which works perfectly in cloned monitor mode with a 3-year-old desktop computer running Windows XP with an ATI card. I have very recently bought a new desktop running under...
Hello
This problem was also faced by me some time ago, i just change the data cable (vga cable) and then it will recognized by system,
i suggest to change the vga cable and try to find the DVI cable if possible to connect the projector to system end.
Hope this helps.
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
I have a dell inspiron 1300 with windows xp, but when I plug in my casio exilim z-40, my computer recognizes the camera but says there are no pictures on the camera (when there clearly is). Is there a...
As computer recognizes the camera but there is no pictures in the camera , To resolve it, visit this link and download both the software mentioned in Window XP section.
Good Luck...don't forget to rate the solution.
I bought a Dell inspiron 400 laptop. I will boot
I would take the hard drive to a computer repair shop and let them scan the HDD and remove the infections. They can also repair the windows installation files so it will boot back up. Either way, you do not have to change out the memory unless you want to install more.
2answers
I have media direct on laptop inspirion 1505...it was not being used and now it comes on automatically and i can not get to opening page for password to internet. when I exit media direct express, the...
First hit ctrl-alt-del at the same task manager will open and you can shut it down there then go to control panel and click on add/remove programs, select media direct and click uninstall
2answers
Usb ports will not recognize flash drive, camera and printer
pl state which pc u hav, its motherboard, the operating system and what anti virus is used?
its quite possible tat ur hardware is malfunctioned, possibly teh operatin system (windows XP / vista / ME / 98) is gone currupt, or simply u can unhook the USB of the printer before restartin it, and hook it again only after restartin it.
Sound Card Driver for Dell Inspiron 1318 in Windows XP
Sorry for the typo, it was suppose to be Dell WEB site
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Digital camera-to-computer USB connection
i have the same problem, between Nikon coolpix L100, and compaq presario v2000 (XP sp3 32bit)
anyone know?
Dec 05, 2007 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
