SOURCE: GE Over-the-Stove Profile Microwave
GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
SOURCE: GE JVM2070CH02 microwave stops after a few seconds
This
is almost always due to a defective or loose magnetron causing electrical
interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on
the list, the same type of problem can occur.
If
your magnetron was recently replaced, it may have loose mounting nuts
or bolts or maybe the wire mesh RF gasket was not installed or got
pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller [email protected]
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are
removed, slide the hood vent grille to the left about 1/4", then then
pull it forward. On some models there are L-shaped clips that fit
into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the
oven and reattach the control panel to be able to open the door.
If
it still does not fail, I would recommend that you put it all back
together and keep using it until it fails more consistently, then
repeat this test.
While
a microwave should never be left
running unattended under any circumstances (as your owner's manual will tell
you) it's even more important when one is exhibiting a failure or any
odd behavior.
So play it safe and stay with it while it's running!
If
you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Sometimes they will
send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful
number here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: GE Eterna Microwave stops after a few seconds, must reset clock..
The
first thing I would suggest is a hard
reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,
leave it unplugged for about 5 minutes.
Otherwise, this
electrical
models are in
the list, the same problem can occur.
If
pinched.
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
do the following:
screws are
back in.
6. Shut the door.
> 0 > Start, e.g.)
NOTE:
If
repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then
(with the power off) tape it over the circuit board as best
you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While
tell
odd behavior.
If
If
You can
download GE
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
very helpful when troubleshooting, testing, and locating
components.
number here.
If
Sometimes they will
number here.
We're
SOURCE: sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
