Master
- Posted on Dec 06, 2010
Re: MY MONITOR SHOWS NO SIGNAL,I HAVE 15 PIECES SAME LIKE...
Check for loose electrical and VGA cables. Remove the
electric cord from the back of the monitor, then put it back in place.
Remove the VGA cable from the computer and monitor and put it back in
place. Make sure the connection is tight. If you're using a cable
extender, remove it.
Plug the monitor's electric cord into a different outlet. If
you're using a UPS or surge protector, plug it directly into a wall
outlet.
Attach the monitor to a different computer. If the monitor
still doesn't work, replace the monitor's cable. Make sure the cable is
less than 5 feet long. If it still doesn't work, the monitor will need
to be replaced or repaired. If it works with no problem on the other
computer, troubleshoot your video card.
Unplug your computer from the monitor and power outlet.
Remove the cover. Pull the video card out of the slot on the system
board. Push it back into place. Be sure the connection is secure.
5
Put the CD that came with your video card into your computer's CD-ROM drive. Follow the directions to reinstall the video card drivers. Download a new version of the drivers from the manufacturer's website if necessary.
6
Right-click a blank area of your Desktop. Choose "Properties"
from the display menu. Click the "Settings" tab. Try different screen
resolutions to resolve the problem.
7
Determine whether the problem is caused by electrical
interference. Electrical interference will make the monitor appear jumpy
or wavy. Move any speakers, radios, fans or other items that can cause
electrical interference away from the monitor.
Read more: How to Troubleshoot a Computer Monitor ' eHow.com http://www.ehow.com/how_2293087_troubleshoot-computer-monitor.html#ixzz17L812lWy
