There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
You scanner Laser Unit is or has failed. You may be able to clear by turning the copier off then back on, if error returns the LAser Scanner unit will need to be replaced.
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
Hi The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up. The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
