Home Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hot water is not coming out the tap in the bath,only slight dribble,it wont turn on fully also.
Anonymous
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Dec 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
118
Questions
Helped
33271
Points
149
Possibly some sediment caught in the cartridge or stem. put some water in a bowl or sink, turn the water off to the fixture, remove the cartridge or stem, flush the cartridge or stem in the water, check for blockage inside valve body, replace parts, turn on water.
1helpful
Childrenlet hot water tap running from gravity fed system, now only dribble coming out. How do we fix
Sounds like an air lock, if its a mixer tap put the palm of you hand over the tap, turn on the cold tap while sealing with your hand then open the hot and wait ten seconds then remove hand seaking tap
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
1helpful
2answers
I have a Fisher and Paykal MW512. When starting the machine on cold cycle the water only comes out in dribbles. On a hot cycle the it will fill but when it gets to the rinse it will not fill with water. Is...
had similar issue - cold water wouldn't come thorugh to fill the drum but the hot would. (changed the hot water hose to the cold water tap as an interim fix). father and husband managed to get the lid off the machine (screwdriver prising involved to flip the lid off the tabs near the front of the machine) then they were able to get in and have a look. ended up being a solanoid (spelling?) that had died. basically this part has magnetic parts to open/close the valve and the magnets had died or something. part replaced -- cost about $65. machine working fine now. hope that helps and made sense!
1helpful
Hi, we have no water coming out of ours taps, in the kitchen=no cold at and a small slow dribble coming out the hot which is cold.The bathroom= small dribble of out of cold tap and small dribble out of hot...
water sounds like it is off at the mains which could be in the flat below , need access to there to check, or it been cut off for non payment , heater would not stop main flow , it is off at the main
best I can tell you ,
1helpful
I have been told there is a way to adjust bath tap temperature under the bath is this true? Thanks
is this a standard bath tub?? if so the answer is no only pressure from hot/cold usually thru the access panel other wise you will have to crank up the water heater unless you have an on-demand water heater located near your access panel. which raises a second question. your faucet? is it a single handle for both hot/cold or two individual handles? if its a single handle try opening up your hot water valve in the access panel to allow for more hot water flow and slightly decresing your cold water valve hope this helps good luck!!!!
Mar 28, 2010 • Home
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 • Home
1helpful
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Bath sink hot tap doesn,t turn open fully
You need to replace stem/cartridge assembly depends on the brand if it is a stem or a cartridge
Oct 02, 2009 • Plumbing
Thundering noise coming from hot taps,bath,sink taps...
Sounds to me like you need to have a water hammer device installed into your plumbing, I have only run across this just once before, the noise is very loud and very bothersome, you will need to contact a plumber and have him install a water hammer device into your system, also vibration dampers would probably help as well, if your water lines are running through floor joists and touching them, hope that helps
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
