Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Can I use Emglo synthetic oil in my EC12 compressor
  • 297 Answers
Yes you can use synthetic oil in you compressor. Emglo just has their name on it. Its ok to use.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 05, 2010
6ya staff
SOURCE:
Compresor will not start under pressure
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However it's not adviseable to run without the thermal reset for an extended time. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background, that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit with no extention cord. But, when using an extention cord, I have a 10 guage cord that will carry the load needed to run the EC12. I also have changed to 100% synthetic oil.
Jul 23, 2011 | Hitachi EC12 Portable Electric 2hp Air...
It is an electric motor Dewalt Emglo Compressor model#D55151. What type of oil should I use in it?
Dewalt recommends using synthetic pump oil, however if you only use the machine occasionally and not in a commercial setting, standard compressor oil will work great and save you money. Synthetic oil will last longer and can take much higher temperatures without breaking down. Lowes sell the kobalt brand of compressor oil and sells for about $3 for standard and $7 for synthetic. Home depot sells campbell hausfeld brand but equally as good. Auto parts stores also sell a line of compressor /pump oil just watch pricing for your needs. If you can't find compressor oil, non-detergent motor oil works just fine. Good holidays
Dec 15, 2010 | Dewalt d55151 factory reconditioned emglo...
What type oil does the Hitachi EC 12 use? Ray
SAE 5W50 and if available use full synthetic.
This link will take you to the EC12 owners manual if you would like.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12__OM.pdf
Oct 28, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Oct 07, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Emglo ku , used low on oil, not sure what type to use
Most reciprocating air compressors use a 30 weight non-detergent oil. Synthetic blends are the most common and least expensive.
Full synthetics are about twice the cost but well worth it, especially for smaller compressors. They dissipate heat better, and won't build carbon or varnish like other oils.
I feel when it comes to oil in a compressor Full Synthetic is the way to go.
Hope that helps,
under_psi
Aug 25, 2010 | Air Tools & Compressors
What oil should I use if Hitachi oil isn't avalible?
On your next trip to Lowes look for Kobalt air compressor oil in the tool department. It sells for under $3 and works great for normal use. They also have Kobalt synthetic compressor oil for extreme conditions and longer use between oil changes. Sell for about $7. I also used Hitachi synthetic oil #19210b 8oz about $8 but hard to find. Kobalt synthetic costs less and works. Good luck.
Aug 02, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
May 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Compressor kick breaker the reset switch want work
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I also have changed to 100% synthetic oil.
May 01, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Overheating? burnt oil smell
There is a seal between the compressor and the motor that in failed condition will leak oil into motor windings causing burnt oil smell. Some hitachi compressors suffered from failed valves or head gasket causing extra heat but not oil smell. These compressors also have a thermobreaker built into the windings that when failed will prevent motor from starting or would start and run for only a few moments then open. This part is not replaceable. enjoy
Oct 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
212 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Ngoro
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
