Is it only the radio that dosent work there may be another fuse on the wire of the radio
yes the radio is the only thing that does not work
are you sure its the radio fuse you replace was it the same type of fuse you replaced it with
The Radio has a hot feed directly from fuse #25 in under left side dash near kick panel fuse box .. also check fuses #14 and #9 .. it is not controlled by any computer module, it could be a burnt out wire ?
The interior lights and door locks/alarm are controlled by the ETAC module .. which also gets its hot feed from fuse # 25 .. but the ETAC module controls lots of other devices including Wiper/defogger/fog light/door warning switch/chime bells etc. etc. and these are working ? it is possible the ETAC module is damaged internally
yep the guy at the parts store helped find it had the old fuse with me
Yes I had a problem for 12 months!! Figured out it was just the yellow butterfly clip that has the 2 fuses in it.. go to wreckers replace with one out of same car and presto works!!
