Toshiba laptop problem when trying to recover: Hello, My Toshiba laptop recently ceased working due to a hard drive error - I inserted the recovery CD and let it do a full recovery - but after a while of it running it came onto the following error message: "imagex.exe - Corrupt File The file or directory C:\Toshiba\Components is corrupt and unreadable. Please run the Chkdsk utility." I haven't clicked OK yet, I'm just wondering if I should do anything from here besides just pressing OK?
Don't be panic. you can try some data recovery software. You can see http://www.asoftech.com/adr/ It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
try this Hard Disk Drive Recovery using the recovery partition You have the options of recovering your system using the Hard Drive Recovery partition to the factory-set default, or recovering just your C: drive and leaving other partitions (for example, a D: drive) intact, or changing the size of your C: drive and then recovering it. To recover your hard disk drive using the utilities stored on your computer's HDD: 1 Make sure the computer is turned off. 2 Press and hold the 0 (zero) key on your keyboard while powering on the computer. When the computer powers on, the Toshiba Recovery Wizard screen displays. 3 Select one of the options, and then click Next. The options are: ? Recovery of Factory Default Software ? Erase the hard disk
1 On the Toshiba Recovery Wizard screen, select Recovery of Factory Default Software, and then click Next. The Recovery of Factory Default Software screen appears. (Sample Image) Recovery of Factory Default Software screen 2 Select Recover to out-of-box-state, and then click Next. A confirmation message displays reminding you that all data will be lost during the recovery process. Be sure to save your work to external media before proceeding. 3 Click Next to begin the recovery. Once complete, a message displays that the HDD has been recovered. 4 Press any key on the keyboard to restart the computer. To recover only your C: drive: 1 On the Toshiba Recovery Wizard Screen, select Recovery of Factory Default Software, and then click Next. 2 Select Recover without changing the hard drive partitions. A confirmation message appears, reminding you that all information on the C: drive will be lost during the recovery process. Be sure you have saved your work to external media before proceeding. 3 Click Next to begin the restoration. Once complete, a message displays that the HDD has been recovered. 4 Press any key on your keyboard to restart the computer.
Hello invest_greec
Connect it to another computer and use Free Recuva works fine : http://download.cnet.com/Recuva/3000-2242_4-10753287.html Do not try to recover all at once but each category at a time , documents , pictures , music ...etc... If it fails , try this one . It's not free but very efficient : Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data due to unwanted erasing , system sabotage, virus corrupted partitions,drives crash, physical damage,ect.. http://www.any-data-recovery.com/product/index.htm If you still don't have success , you will have to go to a recovery office but let's hope not because it will cost you a lot of money .
If above does not work, you may have to format the drive (use quick format), and then use above mentioned software to scan again the drive and recover your files.
try using ActiveBoot suite v5.0.5, when turnig on your computer. This program will scan your computer and show u all the errors,missing files, wrong dll,...and repair them. It worked very well for me as I had a TROJAN virus on my Toshiba satellite 300 and couldn't even boot anymore. After that try use the RegistryBooster tool witch solves every windows problems.
I had error 305: 69 when I tried to repair my sony vgn-ns160d using the recovery disc1. I called sony support and they told me that me hard drive was defective and needed to be replaced. they did not want to send me new recovery discs beause I was out of warranty. I copied the recovery disc at slow speed on another computer and tried rebooting the sony laptop with my fresh copy of the recovery disc. and it WORKED! it was not my HD that was defective it was their recovery disc! sonys support is non existent! trying to sell me a new hard drive!
