Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Check the below link to do a try to correct it -
If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
