SOURCE: Alpine cda 9857
You can download the manual from the link below: http://vault.alpine-usa.com/products/documents/CDA-9857%20OM.PDF Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: i bought a 2002 alpine cda-7892 cd radio i need wiring manual
just run the rca wires from the back of your radio to your amp as well run a direct power wire from your battery to your amp then run a ground wire somewhere on your cars metal surface look for a bolt that you can loosen to whrap the wire around then run a wire from your fuse box tap into a fuse socket that is only powered when the ignition is on you can buy a complete amp wireing kit at pepboys or walmart that will come with instructions good luck....
SOURCE: I NEED A INSTRUCTION MANUAL AND WIRING DIAGRAM FOR A ALPINE CD 78
http://vault.alpine-usa.com/products/documents/OM_CDA-7893.PDF
