Dishwashers Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AEG 6050 will not remain on when on/off button depressed
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Dec 05, 2010
Anonymous
Expert
Level 2:
Answers
70
Questions
0
Helped
18222
Points
134
You will find you will need to replace the switch, as they are normally a non-service part :)
I have an AEG T37400 tumble dryer & the low temp/no buzzer buttons do not appear to be working.
From user manual:
3.
LOW TEMP. button
Pressing this button allows drying to be performed at a lower temperature, for delicate items.
The corresponding pilot light comes on.
This option can also be used for time controlled drying.
This option cannot be selected with QUICK.
6.
NO BUZZER button
A buzzer sounds
• when selecting the programme
• when depressing the buttons
• when an incorrect option selection is made
• when the programme selector dial is turned to another position
during the programme or when you depress an option button
during the cycle
• at the end of the programme and during the anticrease phase
• if the machine is not working correctly
By depressing the button the acoustic signal is switched on.
bez naslova-w1zh3y5hc2yfm4rweyyl043p-4-0.png Dado
Nov 18, 2018 • AEG Dryers
Need an outlet hose for an AEG 6050 model. Where can I get one ?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
3helpful
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
How to Start And use ???
I have the 6040 model, and it has a number of buttons on the left, and a dial on the right.
if yours is the same, then you need to select a program using the buttons "Normal" for example, then turn the dial to just after the top A selection (I mean just after this, by a few mm, it clicks past the A slightly)
this will then do a pre-was, and the main wash you have selected.
The other buttons are fairly self explanatory, like half load for a half load, pre wash to only do a pre wash etc...
Hope the helps!
15helpful
3answers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
