You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
hello, i would suggest manually cleaning the heads,capstan and pinch roller.This requires only isopropol alchohol and q-tips.The metal post coming out is the capstan , if its brown than you will want to clean it back to chrome,above it is the pinch roller clean that as well. Finally there are your heads simply clean the tops of both . Sometimes old tapes become tacky and sticky so consider the age of your cassette as well.
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
You are able to erase tapes on this machine by holding down the play and rewind buttons together. To clear the entire cassette, you'll need to physically turn the tape over and repeat.
