If power light comes on and then goes off do the self check this set has:
when light goes off and front of set press and hold both the menu and Input (device) buttons in at same time for at least five seconds and release both buttons.
The set will (the power light) blink a two digit error code like, 2 blinks, 2 blinks, a pause and repeat the code several times.
2,2 is most common error code, let me know what error code if any you find and comment here and I will tell you what it means.
The self check is designed to narrow down where a problem is.
SD TECH
