If you mean Charter Cable below is a link to there website. Not knowing which remote you have I couldnt post all of them on here.
Click the link below then choose ( Equipment, User Guides & Diagrams) scroll down and you will see 5 remotes. Choose the one thats yours and open the user guide. It will give you the codes and also instructions on how to enter them. In case Vizio isnt listed it will also give you instructions on how to do a TV code search.
http://www.myaccount.charter.com/customers/support.aspx?menuitem=2
If you dont have charter please post again with who your cable service is with and we can help you further.. Good Luck!!!!
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
SOURCE: code for cablevision remote control
Hello Monica24g. I also have Cablevision and found the codes I was looking for. I assume you have an Audiovox (fpe1907) television. Here are some codes you can try: 076 103 043 035 224 228 078. Press the "TV" button and the "SELECT" simultaneously for 3 seconds. The IO button will light up. Enter one of the codes, then press the "TV" button again. I hope this helps!
SOURCE: Need remote control code for Curtis LCD3202A
I just spoke to customer service at Curtis because I had a similar problem. On the bright side, someone responded within a minute of my call and gave me the remote code number which is 2622. However, he also informed me that the LCD televisions are not compatible with cable or universal remotes. The customer service agent's exact words to me were, "you will have to use two remote controls." Sorry for the bad news....
