I have a better solution for you. Download Rufus from Internet and plug USB into computer and USB must be at least 4GB. No Setting changed in Rufus just start. Now your USB will be boot able. Install with USB windows 7 any version. If you want upgrade version then download Daemon tool and mount ISO image from it. Click setup and upgrade procedure will be start. Go with upgrade version. Enjoy..
An ISO file is a CD or DVD image. You burn a disc with this image using a program like CDBurnerXP (a good, free program which is the one I use), or Nero or Roxio which often come preloaded on a system.
If the system has been set up correctly, ISO files should start the burner program for you when you double-click on one. Then you just need to have a disc in the burner and off it goes. Otherwise, you need to start the burning program manually and select the "burn an image" option. Specify the ISO file when you are asked for the image to burn. Do burn an ISO file to a disc using the "create a data disc" option. People often do this and then wonder why the result isn't correct.
Once you converted the ISO image to a real disc, you can either keep it or delete it.
Click OK and it will begin extracting all installation files to the
USB drive. The whole process will take some time(10-15 minutes), so have
patience.
Once the installation is complete, reboot your computer. Now while
your system is starting up press the appropriate button(usually F1, F2,
F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the
startup order to boot USB by default, usually you will have to press F6
to move the selected USB device on top. Once done, save changes and
restart the system.
3rd Method:( Try this if both above methods are not working)
Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
However, to burn disc image to disc is not as simple as disc to computer backup. Many apps support to backup Blu-ray movies from disc to computer or disc, but few of them support to backup movies from ISO file to disc. There is a guide where you will learn detailed and effective solutions to burn disc image file to Blu-ray/DVD disc on Windows and Mac: http://www.leawo.org/tutorial/2-apps-to-...
