Toshiba 57HX83 57" Rear Projection HDTV-Ready Television Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this tv need to have a digital tuner attached to it? or is it ready to use?
Anonymous
Level 3:
President:
  • Toshiba Master 1,779 Answers
  • Posted on Dec 04, 2010
Anonymous
Toshiba Master
Level 3:
President:
Answers
1779
Questions
Helped
578615
Points
5452
You need a HD cable box or go Satellite. That is a monitor set with NO tuner. FYI, the older sets that say HD Ready means No tuner. Salesman jumped all over that one when it came out. They would say Yep! it's HD ready and then jump into all the features to side track the customer, it was terrible.
Hello, I was wondering what board is responsible for the function of switching channels.
Depending largely on the age of the TV, the location of the TV tuner varies. An older analog TV tapping a digital signal does so with an external DTV converter box. For cable and satellite subscribers, there is a a set top box. Most TVs purchased after March 2007 have built-in digital tuners. Look on the front and back of the TV for a marking that indicates a digital tuner. It may say ATSC, DTV, HDTV, Digital Ready, HD Ready, Digital Tuner, Digital Receiver, Digital Tuner Built-in or Integrated Digital Tuner. Any of these is an indication that the TV has a built-in digital tuner. You may have to go to the manufacturer's site to determine such specifications. If you are having a problem with a tv switching channels, remedies may be rather specific and you might try googling for a specific model while including the problem in a simple phrase.
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Where do i plug my cable cord into on my 42 inch sylavania
Hello - The fact is that your TV, as a HDTV ready device, is really a display monitor that does not contain any TV tuner. There is no place to attach your coax TV connector.
To view TV on the unit you would have to either subscribe to cable or satellite TV service or buy yourself an external TV tuner such as listed HERE (I'm not recommending this tuner just showing the kind of device you would need.)
Regards and thank you for using Fix Ya.
Mikeywaf
1helpful
Is the L20V36 zenith ready for the new tv changes
Having looked at the specs for this TV, it would indicate that to receive digital pictures, you would indeed need an external set-top-box, as the tuner in the TV is a standard NTSC tuner, not a DTV tuner.
1helpful
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
2helpful
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
7helpful
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Digiatal tuner
I doubt it. EDTV "ready" usually means that it can read a digital signal if you have tuner. If it were to say "intergrated" that means the tuner is built into the t.v. and you would not need to purchase or rent a tuner.
IS MY TV DIGITAL READY
Its tuner is NTSC, which will not tune in digital stations. I didn't see a DTV tuner mentioned anywhere on the specs, so don't think it will work. I myself have one and will soon purchase a converter box with the $40 rebate from the government.
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
