If you have never replaced the LAMP and Have More then 5,000 playing hours Lamp is bad.
Samsung Parts 1-800-627-4368
Mats has Lamps for $89.00 1-800-628-1118
Hi It is lence problem, first clean the lence by using good quality lence cleaner(without liquid). and then remove the cover and top of the spindle. slightly clean the lence by cotton.Till problem will continue change the lence.
thanking you
hi,if your leance could not open when you turn on camera so may be you must cheak the lence assembly breckeg , if the lence is open then servise lence unit and fix it properly,and the easy way is remove the lence unit and first remove moter from it and rolling well as possible.it must be smoth rolling between beralls of lence,then roll the moter alone well by using adapter about 5 volts,now fix it by aqurat ,you find a magic
first thing i would look at is it is probabily dust on the lences and miror, you need to take the screws out all the way arount the screen from the back, then lean the screen out tward you from the front, do this while the tv is on, you will be able to see the dust alot better, take a soft cloth and glass cleaner and clean little miror, and lences
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
