Have installed the projector in a large pub and having problems with horizontal noise bars about 2 inches wide on a 8 foot screen....Any ideas what could be causing it ?...........Roy
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Hi, I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
